Back
You need to connect your broadband cable
BT Smart Hub 2 - Flashing Purple
How to fix problem:
Check your broadband cable (grey ends) is plugged into your hub and the other end is in your primary phone socket.
If your primary socket has one socket you’ll also need to use the microfilter supplied with your hub - make sure it’s also plugged in correctly.
Need more help?
