Back
Can I connect a device (for example printer, games console) to the Ethernet port of the Whole Home Wi-Fi discs?
Your first disc will use the Ethernet port to connect to your hub/router. On the other discs you can use the Ethernet port to connect other wired devices to the network.
Thanks for your feedback
Submit
Need more help?
