Back
Set up your TV Box Edge
BT TV works best with a direct connection (ethernet cable) to the hub.
For a Wi-Fi connection, it’s all about positioning
Sometimes it's not possible to connect your TV box directly to your hub. Follow the Wi-Fi steps below to see how to set up the best possible Wi-Fi connection to your TV box.
If you’re having issues with your Wi-Fi speed and connection, find out what affects your home broadband and Wi-Fi.
How will you connect your TV box to your broadband hub?
    Show less
    Show less
