How to reset Simpler Networks Powerline Adapters
Here's how to reset your Powerline Adapters if they're not working properly:
  1. Plug both adapters in and switch them on
  2. Use a pen to press the Reset button for two seconds on each adapter in turn
Reset Simpler Networks Adapter
If you've got other Powerline Adapters, you'll now need to pair them again. See the user guide for instructions if you've forgotten how to do this.
Thanks for your feedback
Submit
Need more help?
