Back
Numbers BT will text you from
The UK’s ageing and unreliable copper landline network is being retired.
When BT contacts you, take action to avoid disruption to your home phone or broadband services
Further information and support are available on our Connected Together website, or by calling 0330 1234 150.
We might contact you from different numbers if we've found an issue with your service or in response to something you've done, like placing an order or reporting a fault. It's one of the ways we keep you up to speed with what's going on.
If you get a message from us and reply, we won't charge you for it. But other network providers may charge you at their standard rate or include the message in your allowance. Contact your network provider for more details.
You'll know it's a genuine message from BT if you receive the following:
  • A text message from 61998 or 60204
    If you'd prefer not to receive any text messages from us, just text STOP to 61998 or 60204.
  • A text message from 08456 021 111
    If you receive a call or message from 08456 021 111, it means you have a message waiting. Call 08456 021 111 to get your message.
  • A text message from 81192
    If you'd prefer not to receive any text messages from us, just text STOP to 81192.
  • A text message or call from +44752 0652 012 or +447786202608 or +447908670811
    If you'd prefer not to receive any text messages or calls from us, just text STOP to +44 752 0652 012 or +447786202608 or +447908670811.
Got a text message from Openreach?
Some older devices may show a phone number instead of the Openreach name.
If you'd like to check that a text message is genuine, you can compare the number with the list of numbers Openreach uses to contact customers on their website.
Openreach may send text messages about:
  • engineer appointments
  • broadband installations
  • faults
If the number matches one on the list, you can be confident it's from Openreach.
Thanks for your feedback
Submit
