What is Reminder Call?
Reminder Call acts like an alarm clock on your phone - your phone will ring at the time you program it to.
Maybe you need a daily reminder, or perhaps a one-off call to pick up the dry cleaning. You press a couple of buttons to activate the service, then enter the date and time you want to be reminded. Amending a Reminder Call is just as easy.
How much does it cost?
You pay each time you use this feature.
For our latest prices, please go to the BT Residential Phone Tariff (PDF) and type Reminder Call into the search bar.
How do I use Reminder Call?
Setting up a reminder call
- Press the star (*) key on your telephone keypad.
- Dial the number 55
- Press the star key (*) again, then the required time in 24-hour clock format (for example, 7.30 am should be entered as 0730)
- Press the hash (#) key
For example the full code to dial for a 7:30 AM reminder would be *55*0730#.
Cancelling a reminder call
Press the hash key (#), the number 55, and then the hash (#) key once more(#55#).
Checking the time of a reminder call.
Press star (*), hash (#), the number 55 and then hash (#) again (*#55#).
For more information on using your calling features, download our user guide. (PDF).
