Back
REDIRECTED - Looking for a Digital Voice Adapter?
Image of a Digital Voice Adapter plugged into the mains supply
The Digital Voice Adapter is a simple device that you plug into a power supply next to where you want to have your home phone that uses the Digital Voice service.
If you need an adapter for your Digital Voice service, you can get it by:
  • texting us: ADAPTER to 61998
  • contacting us from your mobile phone on 150, or from any other phone 0330 123 1105
Digital Voice adapter benefits:
  • Easy to set up
  • Plug in your phone in any room
  • Press one button to link with your Smart Hub
  • LED display
  • 1-year guarantee
Find out more about setting up and managing your Digital Voice Adapter: https://www.bt.com/help/landline/set-up-and-use-a-digital-voice-adapter
Thanks for your feedback
Submit
