Back
Test your BT Broadband speed
Use our My BT app or broadband troubleshooter to test the speed of your BT Broadband line.
You can also test your speed using our My BT app.
Download the My BT app >
We measure your download and upload speeds. These are the rates at which data is transferred between the network and your BT Hub. These speeds will vary throughout the day and are likely to be slower during busy periods, especially between 8-10pm. This is the equivalent of the internet rush hour when lots of people are using the shared parts of the network at the same time.
This may be different to the actual speed you receive on your device, which is affected by a wide range of factors. Things like the number of devices connected to your Hub at the same time and whether you're using wi-fi or a wired connection.
If you're not a BT Broadband customer: check what broadband speed you could get with BT >
You may also find these useful:
Five steps to improve slow BT Broadband speeds >
Broadband speed: What is it and how does it work? >
I'm not getting the expected minimum broadband speed >
Thanks for your feedback
Submit
Need more help?
