Back
BT 4G Home Hub
How do I check how much data I’ve used?
You can check your data usage by going into your My BT account online, then select ‘Usage’. Select ‘See BT mobile usage’ - you'll now see your current data usage in GB. Or you can call 0330 123 4150 and speak to one of our agents.
Thanks for your feedback
Submit
Need more help?
